slight squeak from drive belt
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
my drive belt this week i noticed has been a little bit squeaky, i can barely hear it, and i have to be outside the car to hear it, but im scared it may be bad? should i spray some wd40? sounds like a BAD idea lol and its really cold here, maybe thats why? Id look at it but i havent had the chance. I still have another 57000kms until i need to change the belt according to the manual but anybody know the average price for a timing belt change including labour? thx
fueler
Car: 2 Nissan's
2 BMW's
Really, don't WD40 or oil your belt. It's the squeaky wheel that gets the grease, not the squeayk belt. Lubricant can worsen the noise. There are belt-dressings intended to make belts stop slipping, but they are more like adhesives than lubricants.
Timing belt can be anywhere from $500 - $1000 USD , ive seen prices vary
Qxxx4
2012 Ford Mustang
good call, i agree, i heard of people doing the wd40 but it just sounds stupid, ill see if it goes away after the winter or worsens. its only ocassionally anyways. thanks again for your help and ill start putting money aside for that timing belt replacement in the future lol
fueler
Car: 2 Nissan's
2 BMW's
im not gonna lie, i'm guilty of using WD40 a few years ago on my Honda... it was a good temporary fix but a few weeks later the squeal eventually came back worse with quite a furious vengeance! It needed new belts after that.
Andrew224
Car: 2001 Infiniti QX4
2006 Maserati GranSport
2002 Harley Davidson VRod
I've had that same squeak on my truck for about a year. It only happens when it's really cold. Don't worry about it unless it gets really bad. As soon as the temps go above 40 degrees, the squeak is non-existant. There was another post about this within the past month if you want to see what other people said about it. It may also just need to have the drive belt tensioners tightened.
Andrew
Qxxx4
2012 Ford Mustang
thanks alot andrew, i can sleep better at night thanks to you! lol
02pathy
i would say atleast check the belt deflection in accordance to the hayne manual for eg. 1/2'' within 8 or 12 inches and just check for wear and tear, it might be the cold, it getting old or a lil bit out of adjustment
Domenico
Car: 2001 Infiniti qx4
One time i put too much wd-40 and my belt came right off cause i was soo loose....
