Anyone have a slight popping noise that sounds like it’s coming from somewhere in the front middle of your vehicle?
The noise occurred when either accelerating or decelerating, it was just loud enough to be noticeable and irritating over time.
Ours started about two months ago and after much troubleshooting I discovered some loose bolts on 2014 Altima with 80,000 miles,
I’ve ran across one other Altima owner in our area with the same problem.
The bolts in question are under the front mid section of the car and attach the front subframe to the body, five of the bolts have a 16mm head and the sixth is a 21mm head.
They were tight enough to keep things together but just loose enough to make the popping noise.
For what it’s worth I wanna pass this along in case someone else is experiencing the same problem and can catch it before it gets worse.
