Check timing, ohm your injectors, check your spark plugs. That's what I'd try first, in that order.dan4010 wrote:I have a '93 5 spd with an intermittent issue. I would say about half the time when I start up and begin driving the car I have a slight jerking at about 1500-2000 rpm's. It is most prominent in 4th and 5th gears and when I depress the gas pedal slightly. If I drive the car "gingerly" the problem continues, but if I "get on it", let's say in 2nd gear and continue to shift and accelerate normally after, it goes away. I also notice that when it's in its "jerking" mood and I come to a stop, it idles rough for a few seconds then smoothes out. Could this be a valve sticking?
