BBISHOPPCM »
https://forums.nicoclub.com/bbishoppcm-u54071.html
Sat Feb 07, 2009 7:51 am
Can you describe this hesitation? Is the engine stumbling? Does nothing happen until a few milliseconds after you press the accelerator? Because you have a four speed automatic with overdrive, you will notice (for instance, while trying to pass another car), the transmission will downshift depending on how far you press the accelerator (depressing it slightly will generally not cause it to downshift; it might disengage the lockup torque converter, if equipped... depressing it half or full will cause it to shift to a lower gear). If the engine is stumbling (you will usually feel this), it will almost always be accompanied by a check engine light. If you are truly unsure, take it to the dealer and have it looked at. This is the type of problem many dealers will blow off, and pass it off as normal, so try to have a mechanic accompany you; they will generally be more honest if you're actually with them.
