Slight hesitation – stumble, and very slight surging at low RPM’s
Mr.Q45a
Car: 1994 Q45, 1995 Q45a
Hi.
I am experiencing a slight hesitation – stumble, and very slight surging at low RPM’s when taking off from stoplights
My knock sensors need to be replaced, as the code 34 does not clear
I have cleaned the MAF with electrical parts cleaner and checked the connection. I am unable to check the resistance because I lost my volt meter (please see my other post and leave me a recommendation for a voltmeter)
My question is this is a symptom of bad knock sensors or something else?
Thank you for your time and consideration
*bump* I have the same problem! Currently unresolved.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I bet its KS..
I dont remember what my Q was like with bad KS, but it wasnt fun!
areznik
Car: Infiniti Q45 1994
BMW 335i Couple 2007
I know what you talking about but knock sensors won't resolve it (at least I have seen somewhat of this problem after I replaced my KS). I would strongly recommend to put BG44K - it solves many problems including probably this one (no promises though ...). BG44K never hurts. I would recommend to try it first and then go from there.
Andre.
DAEDALUS
Car: 1990 Infiniti Q45
Could be a few things. Besides fouled injectors, how about the TB and intake. They should be clean.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
DAEDALUS wrote:Could be a few things. Besides fouled injectors, how about the TB and intake. They should be clean.
And you will have an excellent opportunity to clean them when the plenum comes off to get to the knock sensors. Don't forget the harness and new hoses.
tiger
yall... I can look through my plenum and see my knock sensor and one of the wires to it is frayed off and not even connected... what is this doing!? Is it messing with my car any? THe code randomly comes into the computer every now and then though.
