dubbs693 »
https://forums.nicoclub.com/dubbs693-u39176.html
Tue May 15, 2007 5:40 am
Hey guys, I am in desperate need of help.
I will try to explain the issue as best I can and list what parts I've thrown at the issue.
Under part throttle I get a slight hesitation in acceleration.. Basically the accel isn't smooth as it should be, It is a lot worse when the engine is cold, when warmed up the issue is still there just not as noticeable. Also the Idle is a bit lumpy cold or warm.. Fluctuates about 100-150 rpm when sitting. The lowest I can get the idle is 800...
I've replaced the TPS and adjusted it within spec.Replaced a clogged fuel filterSpark plugs, wires, cap, rotor.
I have 2 MAFs and when I switch btw both the issue doesn't change.
Changed out the O2 and noticed it was very white. ( I get about 26mpg mix of city and highway) Spark plugs look ok now though..
Its a KA24DE from a 91 240sx, the motor is freshly rebuilt, 20k miles on it.
Any input would be greatly appreciated. Thanks.
Edit - I check the grounds.. Replaced the battery negative ground to the intake mani with a 4 gauge wire.. Also changed the stranded wire ground off the engine with an 8gauge wire.. Sanded down all other grounds that I could see..
Modified by dubbs693 at 11:52 AM 5/15/2007
Modified by dubbs693 at 11:57 AM 5/15/2007
