slight gas fume smell in my 240sx???
blacktopforever
Car: 1993 sr20det 240sx
ok so when im driving along i offten notice a slight gas smell in my car , i have a blacktop sr20det gt2871r the car is tuned and all, so i know thats not the issue, but it is running on a stock exhaust, i had a e cut out exhaust conection , but it stopped working (the e cut out is closed), could the smell be coming from , too much exhaust restriction, would getting a full 3inch fix this problem, (which i planned on doing anyway)
thanks for your time
love boost
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
raw gas smell? every one ive owned had some sort of rubber line leak coming from the tank, i would check there.
White Comet
Car: fc, s13 and mazda6, Sierra
fuel pump gasket?
Wretched
Car: 93' Hatch
^^^ that would be my guess. Those gaskets (o-ring) always stretch when the get gas on them.
Jadesr20det
Car: 1990 NISSAN 240SX
Assuming that you changed your fuel pump when you upgraded turbos, if you didnt change that gasket (o ring ) your going to have that fuel smell I have that same issue now and need to hit up advance to get a replacement. So basically WC is correct
fender-startocaster
Car: 1990 240sx
had this problem with my old car. everyone said it was my charcol canister so i witched it out and the smell went away, but came back within a month or so. Hope that helps any.
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
fender-startocaster wrote:had this problem with my old car. everyone said it was my charcol canister so i witched it out and the smell went away, but came back within a month or so. Hope that helps any.
Doesnt really help seeing that you say the smell came right back...
