slight exhaust problem
zenkii
Car: 95 240sx
I've already researched about this problem for Apexi N1 dual exhaust and did not come up with my exact answer that i was looking for. Ok my situation is, this exhaust is in a s14, how come the exhaust is keep bouncing/hitting the bottom of the car(all hangers are good), also everytime i make a 90 degree turn it starts to hit the bottom again with weird sounds. I know this exhaust heavy, but is there anyway to fix this problem? ...before i swap back the stock exhaust...
dickie
Car: Killer Turtle
have you tried polyurethane thingies to replace the rubber ones? less movement because they are stiffer.
zenkii
Car: 95 240sx
are you talking about the exhaust bushing(the oval one)? If so i just check them out on zilvia, but is there any other ways to fix this problem without spend like $20-30 on that bushing? o yeah i got a bit of exhaust leak too because one of the bolt broke off while taking off the old exhaust
180fan
Car: 89 fastback
Go buy the Nismo ones from Midway. They're doing 10% off on all orders.
You can:1. Ask for Mike Jones 1-866-374-74902. Find the part at Midway Parts Team and put in the coupon code "Merry"
zenkii
Car: 95 240sx
Thanks for the help abut are you guys sure that this will solve the problem?
Tulsa_S-13
Car: 1991 SR 240sx
Solution to fix sagging exhaust hangers: 3 inch worm clamps!
Simply put the worm clamps around the hanger and tighten up, it basically squishes it together and makes it fairly stiff. I've been using them on all of my exhaust hangers for about 6 months without any problems.
dickie
Car: Killer Turtle
thats a good option. get under the car and use your problem solving skills. its not that big of a deal.
zenkii
Car: 95 240sx
this might be a stupid alternative, but would the trusty zip tie work on this one? or would it melt.....
180fan
Car: 89 fastback
it might not melt if you're using a large enough a zip tie, but it could pop or have other crap happen too...
