240TweakerNewbee »
https://forums.nicoclub.com/240tweakernewbee-u27832.html
Sat Apr 29, 2006 6:53 pm
Mine does the same thing, the NISMO thermostat makes no difference. Ive been told its because your not running a cat. I tested that theory by putting on a cat and no more backfiring, but also big loss in power. I used the CATCO high flow cat.
If it backfires excessively you may have it running a bit ritch, best way to figure that out is a day at the dyno with a wideband O2 probe in the tailpipe. If your running an SAFC, youll want to change the fuel curve so its around 12:1, then just set it and forget it, don't start playing with the boost without knowing what your air to fuel ratio is.
