hsi88 »
https://forums.nicoclub.com/hsi88-u225283.html
Sat May 23, 2015 8:50 am
Thanks, I had tried resetting the sunroof before, but did it wrong. I reset all the windows and they all work like a champ. The car had sat for a while until I got my propeller shaft replaced. Another beef. Cannot replace the U-joints. I could have ground the tabs and pressed the U-joint off the yoke, but would have had to spot weld it back into place. Also, because the U-joint had disintegrated, it knocked a piece of steel off the yoke.
Regarding the trailer hitch, I had U-Haul put one on. The ONLY one I could find for the car. Was listed as a 2007, but of course fit perfectly on my 2006. U-Haul was the only place that carried a hitch for my LS400 as well. But will say the LS400 is better suited for towing, drive train wise. The stiff suspension on the M35X and AWD does a nice job towing, but even with a light load, will downshift up hills. But if you have a small utility or motorcycle trailer you want to tow, it does just fine. And of course, the reason I tow with the car is it sure beats the hell out of driving a pick up truck. I live in a red neck town and probably 90% of the pick up beds never see anything beyond empty beer cans!
