C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Thu Mar 08, 2007 5:32 pm
From my understanding, VDC reacts based on inputs from the ABS sensors and steering wheel. Basically, it trys to sense when the car is losing or has lost traction and takes measures to try and regain traction. As to how aggressively VDC will react...well, it's possible, especially in the case of the ABS engaging, that it may provide less braking. Afterall, if you are braking too hard for a given amount of traction, it needs to ease the brake up so that tires get out of lock-up.
In this case, snow/ice, along with the vehicle's speed and desired turning radius was not going to allow the car to make it, VDC or not.
