DeXteR »
https://forums.nicoclub.com/dexter-u32945.html
Thu May 01, 2008 5:39 am
1) Why run drag radials instead of slicks if a person already has a set of street wheels/tires? What advantages are there to slicks?
Drag Radials are usually street legal - slicks are not. Depending on your local law-enforcement, you might be able to get away with slicks on the street.
You'll have to check local/sactioning rules, but I'm pretty sure drag radials allow you to run in a "street tire" class.
2) What are the disadvantages to running slicks? Is there some tire prep involved?
Zero wet traction. They need to be heated up for maximum results (hence the "burnout box")
3) Is the general idea to get as much tread width under the car as possible or is there a calculatable balance between tire size/weight and grip needed?
I believe the word is "calculable". Everything is a cost/benefit equation for cars. However, until you start honing in on a particular time or are trying to shave tenths of seconds to be competitive, just stuff as much rubber as you possibly can. When you need to start gnat's-assing things, then you need to bust out the calculator and figure out the balance between tire size and wheel/tire weight that yields your desired results.
This is just my input on the subject. I honestly don't have a lot of real experience with slicks and drag radials or drag racing. I'm just drawing from my general automotive experience and things I've learned from others.
