sleeve the block?
superman9389
Car: 95 240sx
do i need to seek out a company to sleeve my block if i already have forged internals. i know that it helps make the block stronger but is it needed it i want to run 14psi daily and maybe 20-22psi on the 2nd boost setting. if so what company will do it because i know darton does not offer sleeves for the ka block.
s14det
No need to Sleeve. This is a Iron bock not a Alum. one. Ivan (turbo240)made 1000HP or so at the crank on a stock block. Well around there, so sleeving is not needed. Detonation is the killer on the KA engine. To run 20-22psi I hope you are running race gas or at least Meth/Achol injection.
superman9389
Car: 95 240sx
i will be running the meth/alcohol injection......it will just take me a year or so to get to that point
extreme135
Car: 1995 Nissan 240sx KA-T
superman9389 wrote:do i need to seek out a company to sleeve my block if i already have forged internals. i know that it helps make the block stronger but is it needed it i want to run 14psi daily and maybe 20-22psi on the 2nd boost setting. if so what company will do it because i know darton does not offer sleeves for the ka block.
This is a nissan KA, not a honda B series
Florida240sx
Ka is the truck engine... it won't die unless you F^
480sx
Car: 1996 Pearl White 240sx
The iorn block is your heavy friend, as long as you dont stick a rod through the side of it you will have no problems out of her. Like previously said, sleeving the block is something done with alum blocks, not so much with iorn.
