Sleepy eyes wiring with lights on?
240esX
Car: 1993 Nissan 240SX SE
I have already wired in the momentary switch to control the lights height but i want to make it so i can turn on the lights while the sleepy eyes are on. can anyone tell me wat wires to connect or inturupt to make this possible?
masticatingcow
Car: 94 Mazda FD3S
Hey 240esX, welcome to NICO. What happens when you go for you lights now as you have them wired up? Do the housings open all the way? If so, where did you splice in your existing switch?
240esX
Right now, i have it wired so that when i push the button once to make the lights come up without coming on, it comes up fully like normal, then when i push it again it wont do anything because have it set with a switch (on the green wire) to control the height they go down. What i want to do is be able to turn on the lights while the lights are not fully up, or down, so is there a different wire that controls the high beams, or is there a different way i should be going about this?
Project S13
Car: Nissan 240SX Fastback
There is a way to wire your driving lights to turn on when you switch on your parking lights...if you want to deal with that it's an option. It does look goood if you like the sleepy eye look. Unfortunately I don't know myself the specifics of which wires to cut. I found it a while ago when I was installing my sleepy eye controller (friend bought me the pivot unit so what the heck )
I will try to find that info again for you--I'd do it to my 240 also, but maybe that info can give someone more in the know about 240 wiring enough to figure out what to splice if I can't find it.
240esX
Thanx, alot ever bit of information helps.
CaoBoY
Car: 240sx
not to be an *******, but please search, i found it through search, and just search 'sleepy eye'. theres a thread with a link with pictures and a good write up. its very easy, you just cut 2 wires to do it, and splice in a toggle switch.
Project S13
He didn't ask how to do to the sleepy eye mod, he asked how to wire it so that the *headlights are on while sleepy eyes are up*. Did you read his post?anyway he's right, searching will find it, I've just been busy. Sleepy eye should bring it up.
CaoBoY
Car: 240sx
yea, i know he was asking how to wire it up to have the lights turn on. maybe i didnt make my post clear enough that if he were to search sleepy eye he would find the thread to make it work.
CaoBoY
Car: 240sx
240esX
Thanx for that site and i have used the search and i posted because that link does not show the wires as they are in my car, i guess the wireing changed from 92 to 93 because i have a 93 240sx se and it does not have a silver and blue wire and if it does i can not find it. If you know any other tips it would be grately appriciated.
CaoBoY
Car: 240sx
look for the 5amp fuse in the fuse box. when you see it, go to the back of hte box, thats the wire you cut. its a baby blue wire ( careful, theres a few of em) with silver spots on it. thas what i know, thats what i cut. cut the wire, strip both ends, then put the toggle switch on it. bam instant sleepy eyes with lights on.
masticatingcow
Car: 94 Mazda FD3S
Awesome. Very straight forward.
240esX
i finished it and it works perfect thank you.
CaoBoY
Car: 240sx
now whore out some pixors to show how badass sleepy eyes are!
240esX
they have already been posted on my homepage
http://www.cardomain.com/membe...age=1
Project S13
looking good
st33f
Car: 1990 240sx - redtop sr20det, T04B/T28 hybrid, UG coilovers, 3inch turbo back
look at my post in general... also my diy is goin up on it now...
Wraith 240
Car: 1991 240sx Fastback
240esxcan you explane how u did the lightz i looked on the Cardomain but it was wear sounded easy but he said like thiz and like below but i saw kno picz can u explane please im doing them later 2day
240esX
CaoBoY wrote:look for the 5amp fuse in the fuse box. when you see it, go to the back of hte box, thats the wire you cut. its a baby blue wire ( careful, theres a few of em) with silver spots on it. thas what i know, thats what i cut. cut the wire, strip both ends, then put the toggle switch on it. bam instant sleepy eyes with lights on.
Wraith 240
Do you cut the one that has the Silver spots?and itz the kicker panel thatz on the driver side correct
Wraith 240
Can you Please take a picture?I cut the wire but the lightz did not come on.
Also what is the order?
titanium240
Car: 1986 Ford Escort
Dude, read the post again, it's not hard to figure out. I could do it without instructions after reading it three times - and I have never been in a 240 yet.
CaoBoY wrote:look for the 5amp fuse in the fuse box. when you see it, go to the back of hte box, thats the wire you cut. its a baby blue wire ( careful, theres a few of em) with silver spots on it. thas what i know, thats what i cut. cut the wire, strip both ends, then put the toggle switch on it . bam instant sleepy eyes with lights on.
Key point - you don't just cut the wire and let it hang, connect a toggle switch to the wire and you'll be on your way
Wraith 240
Well i cut the wire and put a toggle switch but the lightz still didnt come onso i was asking a QuestionBeacuse i tryed it
240esX
ok, so u cut the blue and siler wire behing the 5amp fuse, put a toggle switch on it and its still not working? what happens when u try and put ur lights on?
Wraith 240
when i put my lightz on they poped all the way upthen i made the lights Sleepy with the Button that makes the light go up and downturned on the switch and the lightz went down then back up
Did you cut the Brown wire as well
240esX
Ok u might just be trying to do it in the wrong order its sumwhat weird to do -
ok so first u pop the lights up and then down to the setting u like for the laziness, then u disconted the circut to the blue/silver wire with the toggle then turn ur lights on
if ur talking about the brown wire with the momentary switch behind the headlights up and down button yes i cut it also.
thats what i did if that doesnt work u probly cut the wrong wire in the fuse box by the clutch pedal
Wraith 240
ima go and get a new toggel switch and try agian 2morrow thx alot So itz the Blue wire that has silver spots on it correct
240esX
yeap light blue if i remember correct
Wraith 240
i got itbut didnt use a switchi just pulled the fuse
