Newcastle82 »
https://forums.nicoclub.com/newcastle82-u13870.html
Tue Aug 24, 2004 8:52 am
Alright, like previously mentioned, there are MANY sleepy eye mod threads started already.
In a nutshell, the easiest and most cost-effective way to pull this mod off goes as follows:------------------------------------------
1.) Get some electrical tape and a pair of wire cutters2.) See that button on the left of your steering wheel, the one with a picture of a headlight that manually raises and lowers your headlight motors? Pull the button OUT of the dash.3.) Find the brown wire in the cluster.4.) Cut it.5.) Use your tape on both ends to prevent possible shorting.6.) Pop the button back into your dash.7.) Push the button and use your headlight/signal knob to turn your headlights on. They should pop up and turn on.8.) Now turn them off - notice that since your hold wire was cut, your lights turn off but the motors do not lower the lights.9.) Now, manually push that button in and quickly push it out, continue this and notice how your headlights 'ratchet' down towards a lowered position.10.) Continue until your car looks WAY stoned.
