DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Sat Oct 01, 2005 1:27 pm
on my hatch i did the cut the wire thing, and it really worked well for a while, and then they got uneven and they are still uneven.
on my coupe i just disabled the motors, which i highly recommend (actually my car has a weirdo electrical problem and only one light moves up and down, but when you press the headlight button it shuts off my driver side headlight, its actually kinda cool, i can wink my headlights at you)
but if you want useful headlights adn you demand your car to look stoned all the time i recommend you do what i did. Ditch the headlights all together, pull the harness from the headlight motors, and buy a set or two of foglights. Gut one set of foglights and put your headlight bulbs in there. Then mount this and maybe even another set or circle foglights on the top beam of the headlight assembly. Now you always have working headlights, that actually point somewhere, and you dont have to mess with the knobs ever again.
i have one set of circle foglights and one set of rectangular fogs with headlight bulbs for my headlights, and then i stuffed another set of fogs in the grills on the front bumper.
its bright and it looks SO SO good when its on, plus during the day i can just turn on the circle fogs and it looks like i have daytime running lamps ( i really need to get you guys a picture)
this is absolutely necessary for me because i use the headlight as a scoop for my cold air box, and with everything removed the path for the air feeds directly into the cold air box
so to answer your question again, just pull the harness or the relays, i just pulled relays
