koukikid wrote:okay so i turn the knob, but the stupid motor keeps spinning back 'n forth....what do i do about that?
Like Axel said, - cut the brown wire. You can do a search and there is a whole process on how to make it work.
If you want to use the knob turner, you have to unplug the motors (near the motor below) just trace the line.
Then you will be in permy sleepy eye if you do this way.
If you do Axel's way, you just have to be very fast w/ the clicking (you'll understand once you search)
