pmkls2 »
https://forums.nicoclub.com/pmkls2-u8760.html
Fri Jul 02, 2004 9:00 am
Well, it is very simple but you need to be careful. Just undo the line coming into the dampener from the master cylinder. Then undo the line from the dampener to the rubber hose at the hose end. Then remove the dampener from the vehicle and toss it in the trash where it belongs. The next part is where you need to be very careful. Take the line coming from the master cylinder and GENTLY bend it around towards the hose until it reaches, it is pretty simple just be careful not to kink the line or you will have to replace it. then just screw the line into the hose and bleed the system. It isnt a bad job at all, it took me about 10 minutes, but just take your time and you shouldnt have any problems.
