Slave Cylinder?
SRJesse
Car: Cars, hockey (roller and ice)
Hey guys, Just wanted to know what Clutch Slave cylinder will interchange with the SR20DET transmission. I dont know if they are even much different than the U.S. transmission. I ordered a U.S. 240sx slave cylinder, and I am hoping someone can confirm that they are the same.....
Thanks in advanced guys.
matt240det
99% sure they are interchangable
Ace
Car: S14
I don't know if you have your SR yet or what but my SR20 came with a slave cylinder bolted up in great shape. I also got a manual KA24DE slave cylinder before I got my swap because I thought my swap wouldn't have one. Anyway the KA slave cylinder will work.
SRJesse
Ok great thanks. Yes I have the SR in already. I have had it for a while and the other day the clutch went right to the floor. The slave has been leaking a bit and I guess it just decided to finally go the other day. I told the mechanical shop I had a 90 so I hope it doesnt matter between SOHC and DOHC. I dont know if they would be different anyway. Thanks for the info though guys.
BuudWeizErr
My SC from my KAE was exactly the same. Shouldn't be hard to find one. You might want to look into a Nismo SC also. Jspec.com has them I believe.
