Slave Cylinder different???
Oceanblue
im thinking of replacing my slave cylinder since my gears are grinding a bit, i was wondering if there is a difference between nismo slave cylinder and the oem s14 1? the difference is 150$ us... i dont know if its worth it.. would i be buying for the performance, or would i be buying for the name??
180fan
Car: 89 fastback
Nismo makes it a bit easier for you to press the pedal down without so much effort. If you've got a stock or near stock pressure plate, not worth it.
Oceanblue
thanks man, thats what i thought too
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
180fan wrote:Nismo makes it a bit easier for you to press the pedal down without so much effort. If you've got a stock or near stock pressure plate, not worth it.
So much effort?? The 240 pedal pressure is too soft as it is!
180fan
Car: 89 fastback
When you go to heavy duty pressure plates vs the stock one. Hence the comment of "stock or near stock" that it won't be worth it.
