blackbeltclub99 »
https://forums.nicoclub.com/blackbeltclub99-u3550.html
Wed Nov 03, 2004 6:36 am
I have a 89 coupe with a 98 S13 SR20DET
I was on my way to work this morning and went to change gears and the clutch stuck to the floor. I pulled over and checked to see if anything was loose or had fallen off, but it had not. I went back home clutchless shifting, made it fine. I had my wife push the pedal in (moves about 1 inch) and the entire clutch line like pops alittle bit(it is kinda like if you stip a screw how it pops right before loosening up again). The slave cylinder moves just a hair then pops back in. Fluid leval is fine too. anyway do you think it is the slave cylinder? If so which one do I need to get(I mean which one is for my car)?
Modified by blackbeltclub99 at 5:28 PM 11/3/2004
