boost_creep »
https://forums.nicoclub.com/boost-creep-u18562.html
Mon Aug 08, 2005 2:34 pm
within the last couple of weeks ive noticed a slip in second gear,at wot.ive got ten thousand miles on a spec stage 3.the flywheel was resurfaced with a step on it.im not sure if this is correct either.ive checked all the obvious.boost leak,vacuum leak,ignition timing,new clutch master cylinder,blead it numerous times,moved to a fmic,and still the lag,or slippage is there.how long should a spec stage 3 last,and is it possible that the slave thats on my car is not correct.its the 91-94 which is a 3/4 and the correct one for the 89-90 is a 11/16.please give me ur suggestions.
