Slave and master cylinders
Logan76
Car: Junk
would I be able to use the CA18DE ones? i mean i would love to go to advanced and be able to get these parts, does anyone know if theyll work and if advanced or autozone would have either of them? thanks
driftin8ez
Car: 92 Coupe, Turbo Miata
You use the 240sx master cylinder. The slave.. I'm 90% sure when i did my swap i took off my KA transmission. So go get the parts for what ever year your 240 is.
Logan76
Car: Junk
Really? its in a 91 240sx so that would be the KA24DE or what should I do, I just know my clutch wont build pressure even after we bled it for like 2.5 hours...thats my only thoughts that is could be the master or the slave.
driftin8ez
Did you remove the clutch damper box? That thing can make bleeding a new system a nightmare. CA, KA, and SR trannys are identical besides 5th gear and the bell housing. So that makes me belive that all the stock 240 stuff will work.
Logan76
Car: Junk
Nope havent bypassed the dampener box yet. i may replace the slave and master cyl. and then bend the hardline.
Indecisive
Car: 1987 200sx Turbo
when you bleed, be sure to release bleed it from the damper box first then.
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
go to autozone and order the slave for a 89 or 90 240sx. the part number for 91+ is wrong, and it has been for a while.
get a hose too if you got the extra 10 bucks
slave is $13hose is $10.
Logan76
Car: Junk
we figured out the problem, its my clutch master cylinder, and i think that goes by the year of the 240 no matter what motor i have.
ca18datsun510
i know that, you know that.
autozone doesnt know that. just in case you go there.
the part number is 10282 for the right master cylinder.
trust me, ive been down this road.
Logan76
Car: Junk
**** I already got it, wonder if I got the right one, I just ordered a Clutch Master Cyl. for a 91 240sx.
