i wan
RM12577 wrote:yea after some more reading i decided that a vmount was the correct terminology, not something i had ever realized that anyone did other than the slanted radiators on firebirds, least that was the first one i had ever seen... my car doesnt really get too hot even in the middle of summer in houston still stays a little below the middle of the temp gauge, so I dont think ill need to worry too much about heat, and i usually am pretty rough on it, I do plan on doing that GT28R and if i went vmount i would get some thin aluminum to make some nice ducting and run my electric fans, i was looking at it today and i think i could set it up without having to cut any of the radiator brace thing... too early cant think of the name, I would have to blast a nice slot in my hood but that wouldnt really bother me, hood has a few dents anyways, and i have a spare set of top radiator mounts that i would cut and modify to make some new mounts for the radiator, then just some custom hose lengths and some short intercooler tubing I would think, anything else that I should run on it for a vmount? maybe cut some bumper material out to get even more flow or something?
i wanted to go vmount for the longest time unti l i went to my local shop(ZeroLift) and thalked to the owner, whom i know, and the vmount with even a good koyo was running hot, the coolant would lay in the radiator too long causing poor flow through the radiator and back into the motor, they had a custom radiator made and did verything custom .
its a hard process. i am going with a water to air intercooler setup. not too pricy and VERY effective. DIY pipe kit and a air/water kit for under $300. from this site, very nice and is what i want to do.
