centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Thu Jun 01, 2017 12:01 pm
Hmm, I don't think the seal is your issue. It's not so much a shock absorber as it is just a seal for the air.
There's a door latch and door catch. Those can be adjusted. First make sure there's not too much sag in your doors hinge. So open it all the way and see if you can lift it up and down. Shouldn't go more than 1/8th or 1/4" vertically. If it does, you'll want to replace your hinge pins. Once your door isn't moving up and down, then you move onto the latch area. You want to loosen the bolts on the door jam latch hoop and move it in a direction, like down and out usually. Then tighten temporarily and test door closure. It may take a few tries to get it into the right position. Once you get it dialed in, tighten up the bolts all the way and you're good to go! I could be wrong, but I think you should give it a go. You'll save some $$ by not buying seals!
