philipa_240sx »
https://forums.nicoclub.com/philipa-240sx-u68765.html
Wed Mar 04, 2009 4:23 pm
The SL standard is prior to 2005, when the SM standard was introduced. Using an SL rated oil in 2005 and newer vehicles is not recommended. The standard exists for a reason as engine mfgs. are constantly improving their products and require oils which lower deposits (sludge), do not contaminate catalytic converters, and meet certain wear requirements. The SM rating is an improvement over SL in these respects.
Not using the 'proper' lubricant can void the warranty. It's written in your warranty booklet on page 6:
Quote »WHAT IS NOT COVERED
DAMAGE, FAILURES OR CORROSION DUE TO LACKOF OR IMPROPER MAINTENANCEThis warranty does not cover damage, failures or corrosionresulting from:...■ Use of improper or dirty fuel, fluids or lubricants.[/quote]
