krispenev »
https://forums.nicoclub.com/krispenev-u51771.html
Sun Aug 05, 2007 6:44 pm
OK, hopefully you guys can give me a helping hand here....I need it.
My RB20 has been giving me nightmares the past 2 days. After I dusted some kid in a Mustang, my Skyline overheated badly, and I've never seen a car do it as bad as this. I parked the car, and popped the hood. What I saw almost put me to tears. '
There was steam coming from the back of the engine , right up against the firewall. I took a look underneath the car, and the coolant was leaking underneath the transmission, infact, it was leaking and hissing all over the transmission near the firewall. I cant see where it was coming from, but it was dripping on the transmission. What the f___ is back there that it could be leaking and hissing like that?
Would a broken line cause the engine to loose all that coolant and overheat? I understand that I could be a bad hose or something, but that should never cause it to overheat, should it? The coolant should still circulate through the system.
I dont know what the do.
The rad is good, and so is the thermostat. I had those checked when I bought the car. The cooling system was a little clogged, but after they flushed they system, everything was flowing perfectly, so I dont think it is the obvious things.
If anyone has any ideas, I am all ears. The car is basically stock, except for exhaust, blitz ecu, blitz bov, and suspension work. From what I know, the boost is not increased from stock aswell.
Thanks a million.
