Skyline r32 injectors on 300zx. Also other questions.
flyhotstuff
Car: 1993 300zx Twin Turbo
my friend is planning to upgrade his skyline injectors to 1000cc's and is willing to hand over to me the stock injectors with the red caps. I am wondering if those injectors are the same ones that work on the 300zx. i can't seem to find information on this, thanks.
also i have no A/C belt on, how can i install the a/c belt without removing the radiator.
And my gas tank is not holding any pressure, limited options of finding someone to test it as i am in the caribbean. any ideas? thanks guys.
NolimitZ32
RB 25 & 26 injectors are interchangable with the Z32 (as long as they are the correct phase/generation as in new style/old style) the rest you'll have to figure out yuorself or provide pictures and more info on both cars/engines.
ThisIsSparTTa
Car: 91 300ZX TT 2+0
AC Belt doesn't require removing the radiator. I can't remember the order on the crankshaft pulley, but at worst you'll have to remove the Power Steering and Alternator Belts. All that info can be found here: http://z32.wikispaces.com/
DCaff300ZX
Car: .
1993 CRP TT- Modified
It's a PITA to be sure but can be done with patience, the key is after removing the other belts and fan loosening the A/C idler/tensioner which will JUST allow you to finagle the belt on from above, fighting the shroud and I/C pipes if you have TT.
flyhotstuff
Thanks guys. someone jacked the car up by the radiator mount and the hood won't close completely. i figure it's a good time to have the radiator removed and bend it back into place.
flyhotstuff
Can anyone point me in the direction of finding out weather an injector is a Phase 1 or Phase 2 injector. thanks!
RubyRed300ZX
Car: 1993 300zx Convertible
Phase 1 is the old style 1990 to 1992. Phase 2 refers to 1993 to 1996, or whats is also called the new style. Phase 1 has a square/rectangular electrical connector. Phase 2 has a has a more oval shaped connector ( square but with the corners distinctly rounded). This refers to the shape as you look straight on at the pins. Most retailers online will show two or three views so that you can see the difference.
