SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Sun Nov 21, 2004 6:51 pm
The ECR33 MAFS is an upgrade over the SR MAFS because it will register power up to 350 hp while the SR stops at about 280. The later model ECR33 MAFS with the three plugs supposedly reads air better at low RPM's when compared to the Z32 and early ECR33 MAFS.
As for wiring, the red box is the 12 Volt power source, the blue box is the ground and the purple box is the output signal. I dont know what the orange box does exactly, though that wire is not used on Z32 MAFS conversions so I doubt its needed with the ECR33 conversion. However it does show that it is a negative wire so if you wire everything up correctly and still have MAFS issues, try grounding that orange wire.
