Skyline GTS-T AWD question.
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
Mancool89
Car: Skyline GTS-T
Hello, I am 17 years old looking into buying a GTS-T ( 1990 ). I was curious about the AWD on these cars, is there an in car switch to put it in RWD or FWD? or is that all aftermarket ? also, do these cars have HICAS ( all wheel steering?) Thanks alot.
themadscientist
GTS-Ts are RWD. GT-Rs and GTS-4s are 4WD. You can buy after market torque split controllers. For an R32 you can pull a fuse and instant RWD.
nikko123
Car: Skyline R32 GTS4
Hey kid I own what you want but mine is a 1991. Its called a GTS4 there is another GTS4 selection but the Rb20 powered one is the only turbo version.
It is AWD but not continous like the STI's or the Evo's. It distributes balance throughout all 4 wheels during troubling situations. It uses the same clutch and transmission as the GTR but a diffrent gear box IE same ish diffrent shorter gears. It has HICAS but YOU DONT WANT IT!!! but it uses the ATTESSA system just like the GTR. Its a good buy. Also there is a relay located under the hood. Pull it out and unplug your battery to reset your ECU and now your car will become RWD so you get the best of both worlds.
You share the same suspension as the GTR as well so be weary if your money is low I am in Japan so this stuffs cheap I MEAN CHEAP I got Cusco Comp 1 suspension for 300 bucks and I was trying to go lower.
Get your self a boost controller go to 1 bar (14.7psi) and have some fun if you have any questions hit me up...
stud240sx
sweet but idk
redsilvia
Car: 1990 NISSAN 240SX BASE COUPE/1993 NISSAN 240SX SE HATCH
save your money and get the gt-r.
SKYLINE GT-R
Car: Nissan Skyline GTR R32
hi kid
Mr.nikko123 is right, but i think if you buying the GTR is better,you know why??
just for the RB26DETT and GTR transmission and some aluminum body parts
good luck
Scram
Car: 1992 Nissan Skyline GTS-4
As far as I know the GTS-T wasn't all wheel drive. That option only game on the GTS-4. And it's a selective AWD only kicking in when torque requires it. I actually have a GTS-4 and there is an extra gauge on the dashboard for the front wheel drive torque. Hope this helps.
Scram
I didn't know about the relay in the engine compartment though. Awesome info! If you happen to have any diagrams on which relay, I would be indebted to you.Thanks again,Scram
Return to “GTR Forum / Skyline Forum”
