Skyline GTS Brakes?
240SXplan
Car: 1990 240SX
hi guys..
I have the skyline brakes.. I have a 1990 240 SX .. how do i make it work?
I got the rotors.. and calipers also. brake lines too.
tia,
plai
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
The same way you make the 300zx ones work.
Carl H
yup.r32 gts-t type m brakes are the same as the z32 brakes.they are the 30mm al calipers if you need to get parts for them.i made ss lines to connect the brakes to the hardlines.cost me ~70$ for both lines.
240SXplan
Car: 1990 240SX
Well.. I did not know that..
I'll do the rsearch a little more..
thanks..
plai
blk90s13
the question is wut offset wheels will clear ?
Carl H
it will clear stock se alloys (91-93) with a 5mm spacer.dont forget wheel studs if you use a spacer.
