SpartanAir »
https://forums.nicoclub.com/spartanair-u59789.html
Thu Feb 05, 2009 10:02 pm
This seems like a strange/rare question, but I need a serious answer.
Has anyone ever attempted this? My car came with a retrofitted GTR suspension setup, however now the front are blown, and I need a replacement.
The car is a 1992 Nissan President Sovereign.
The car originally had active, but was disconnected and plugged.
I'm now considering my options for suspension, and by doing alot of searching on this site, I've deemed it worthwhile to not resurrect the active suspension, and go with a standard setup. Which setup, is the question.
The rear GTR struts bolt up no problem actually, but its the fronts I have issues with. The shop that threw on this suspension fabricated a crappy ball joint on the front struts which has ripped apart and is falling off. Oh, and I mentioned the struts are blown
The upper mount for the strut works fine, it's the lower ball joint on the GTR strut is too small for the threaded bolt on the knuckle arm.
I've actually tried to fit GTR knuckle arms on the car, which seemed to line up fine, and bolted all up, but once mounted, the front camber was far too negative to be safe.
My options as I see it are:
- Have a fabrication shop bore out the old joint on the strut and weld in a new one that fits the knuckle arm (rubber bushing might be a problem)
- Have a fabrication shop weld on a smaller threaded bolt onto the knuckle arm
- Use Tokicos with lowering springs
Now, the last option seems simplest, but because I'm looking for adjustability in height because my car is "VIP-styled", the GTR coilovers would be awesome to have for that reason. With the Tokicos, I'd be stuck with a set height.
Now this is probably a crazy crazy post/idea/project, but I've been racking my brain, my shop is getting as frustrated as I am, and I'm running out of time because I need my car on the road.
Any help is appreciated! And please seriously consider what I've said, because I am serious about what I want to do with this car.
Oh, and when I get time I will likely do a proper conversion and rip out all the active suspension components, and sell them to anyone on here who needs them
Thanks,Brendan
Modified by SpartanAir at 2:05 AM 2/6/2009
