gabossie »
https://forums.nicoclub.com/gabossie-u1022.html
Thu May 13, 2004 9:55 am
Niether of those statements are entirely true. The RB swap is NOT as expensive as most think it is, although it certainly can be if you choose to make it that way. An RB25 is definatly more expensive than an RB20 (which can often come in less expensive than an SR swap). You don't NEED custom mounts, but you can use them. Do some research before you ask things like this, we have the best RB section on the web, bar none. The info you need is there. The Skyline front end conversion has been done, and does bolt up to a certain point. You will need to do, or have done, some custom body work to get everything flush, and it's probably more money and trouble than you're looking for, then again, so is an S15 conversion.
To get you going, here's the RB section:http://www.nissaninfiniticlub....d=135
