hole to hole. that is y i said almost 100% positive cuz i know for sure its 768mm but i dont know if it was from hole to hole or end to end. im leaning towards hole to hole. worse case scenario if not that then u only need to add 1in max for total length or width i guess you could call it. it wont be less than 768mm. i think that is a pretty good measurement for what u need.
gtr x-member is different because of axles running from front diff. the x-member is rounded downward at the ends like a U to accept the axles going through it.
the other cross member is just like a rwd x-member. it is "more" flat throughout.
ie. the dip on the rb25 x-member has a small rounded slope to flat towards center then it goes back up.
gtr is flat but at the ends it rises up with a U type connection to frame with a gap in center to allow axles
hope that helped and made sense.
Carl H wrote:frame rail to frame rail mount yes they are the same...
i second that! Carl H seems to know his stuff
