I don't mean to be off point, but can you tell me how did you rebuild the Q's motor? According to everyone on this forum your average machine shop does NOT have the necessary/sophisticated enough machines/tools for that type of job.carfrk666 wrote:........................motor rebuild long time ago, .........................
well at the time i had worked in a machine shop, it is 100% possible to rebuild that engine, the harder part is finding parts for it and then putting it all back together, but i went and ground all my valves and cut all the seats for them, i only ball honed the cylinders however u can also use a hone machine and bore it if u can find the pistons and rings for that, the rods where reconditioned and the crank was ground down a bit, its not a bad project to do either, if u want more infoabout it then u can email me or something.ddrumman wrote:
When I had that problem, it turned out to be an injector.96Q45GAL wrote:Not sure if you have the same problem I have been going through? If I go on the highway...When I get to about 50-65 and let my foot off the gas...It starts skipping/bucking!??... I seem to have a MAF issue... So check into that if you havent already?
