Chris859 »
https://forums.nicoclub.com/chris859-u44940.html
Sun Mar 16, 2008 4:14 pm
Not to mention when you start milling a decent amount off of an OHC head your cam timing will change in relation to the crank as well... so a set of adjustable cam gears, and equip to properly degree the cams would be ideal. My advice - find a trashed ca18 head - find out how far you have to cut it to get the required combustion chamber cc reduction. After you get that, verify you still have enough piston to valve clearance to run safely(this is an interferance engine to start with, so you dont have much before you have to flycut the pistons further). Just some quick thoughts from me... do-able
