mikeG wrote:A piece of string.
Find a large open parking lot that is flat and level. Pound a nail in the parking lot surface and tie the string (15'11.1''long) to it. Get a can of spray paint. Paint a circle. Holding the string driectly against the can will give you a measure of 15'11.1''. Thusly, as you walk around the nail, you will create a circle with a circumference of 100 FEET. 60 MPH around a 100 foot circle is 1G. Do the math to find what your car is pulling before you break loose. (30 mph=.5g, and so on.)
should i try to keep the inside edge of the car to be on the line or try to keep the line directly underneath the middle of the car when doing this?
