Sketchy white smoke.
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
sick skyline
Car: Nissan skyline r32 rb25det
So im getting some white smoke every so often, and my dip stick popped out, could this be a sign of a bad head gasket?
themadscientist
Could be. Check your radiator for oil and your oil for water. Coolant temperature rise suddenly under boost?
sick skyline
No i got the checked out, its all good, but i accelerated fast on the highway today and smoke started billowing out of the valve cover, i also have an oil leak coming from where the smoke was, Valve cover gasket?
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
excessive smoke coming out of the valve cover? like out of the emission tubes? sounds like a ring or ring land, exp with you saying you blew the dipstick out.... excessive blow by
sick skyline
No its just coming right out of the side of the cover.
tyndago
Do a leak down test. Check #6 first. Poping out the dipstick tube is normally a hurt piston.
White smoke probably on lift right?
Return to “GTR Forum / Skyline Forum”
