BETOLGRANDE wrote:O'm kind of new with the truck. Where is it.? Whats the best way to do it?
I think this will be your MAF:
(circled in
red)
You need some MAF cleaner:
You also may require
a security Torx (probably T20) bit to remove the MAF sensor. At least, I required one for my VQ35 in the '01.
Disconnect the negative on the battery, remove the wiring harness for the MAF sensor, unscrew it, and the MAF should just rise out of the throttle body intake tube. Spray it with cleaner liberally around the exposed wire, like so:
(picture is from an R50 MAF, pic taken by
kkamakasi)
Wait for it to dry, reinstall it, reconnect battery cable. Done.
