size help
glitched
Car: 1992 240sx se
Man, i feel like such a noob for asking these questions, but i want to make sure.
I will be running a 225 width tire. will be on coils
for the rear, how will 8in 0 offset fit compared to 8.5in -6 offset?
that's a difference of 1/4in wider on both sides, right?
would that put the wheel edge past the Fender?
Will camber be enough to fit, or will a roll be enough?
Gabes13
Car: rb20det s13
?x8 +0 is enough to stick out about an inch. more with the bulge of a 225 and even more with 8.5 -6but both will be fine with about -3 degrees of camber though
edit: 225 with stretch a little on the 8.5 but would fit more or less the same as 8+0
glitched
Car: 1992 240sx se
yeah, i'm leaning more towards the 16x8 0offset rather than the 8.5 -6 offset.
but if i understand this correctly, the tire will fit the same under the fender on either size, but just be a little stretched with the 8.5
I've found a couple pics of guys running 8in 0 offset from fit databases. and they look almost exactly even with the fender.
The reason i think i'd go with the 8.5 over the 8 is cause it would probably look better, but i dont even know that for sure...
Gabes13
Car: rb20det s13
yeah, 225 will stretch just a little on the 8.5.
people tuck the 8 +0 quite easily on stock fenders with just a tad of - camber.lets do some math.
8 +0 is 4" front space and 4" back space.pretty simple.
8.5 -6 will be 4.48" front space and 3.52" back space, if i did my math right.
so the -6 will stick out ~0.5" more than the 8+0s but the tire will stretch a little more also.
Im running ~4.11" front space and 4.89 back space with about -2 deg of camber and would like to go a little lower offset.
~4" front space seems to be the universal "flush fitment" for the 240
I think you should go for the 8.5 and do whatever it takes to make them fit.
