size and placement of main bearings
blackhole1
Car: 95 s14 sr20
whtz up nico club, i building an my sr engine for the first time never touched an engine before. after reading alot of threads of other mistakes and experiences with building i have learned a lot enough to give me the courage to do it my self plus to pay someone to do the swap and up grade was out of my money range, so here is my delema i am replacing the main bearing and and kept the old ones in order to dial the out first I took the 5 digit block number wich is 02211 and the crank number is 02110 i added them together getting 04321 is this correct? my other question is, the firs grade number is that the first journal number does the first number 0 go to the number one crank placement and the number 4 go to the number two crank placement and so on i have come this far to mess this up, can anyone help me out and also give good advice, I also read hijackers engine build thread and it has helped alot.I also have a cosworth 87mm 1.5 headgasket will this be fine with the stock turbo it's a garrette t28 for a s14 everything is upgraded except the injectors i do plan on upgrading the injectors and turbo in a year or so hopefuly sooner
Modified by blackhole1 at 6:20 AM 6/14/2008
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
Race bearings like ACL use standered size bearings. If going oem than its best to measure all clearances and get the correct grade's and sizes as there is alot of choices. I would spend the little extra money and go aftermarket, but Nissan makes some very good stock bearings that shouldent needed upgraded unless going all out on your build.
blackhole1
Car: 95 s14 sr20
I am going oem just need to know in what order they are put inplace on the crank and did not go up grade the reason is not going over 400 and stock botton end can handle that much power also got the pistons and rods ceramic coated to help with the heat load on the rods and pistons so i dont have to worry on bending brakeing a rod hopefuly. ok what i relly want to know is what order does these bearings go in.
Modified by blackhole1 at 9:29 AM 6/14/2008
