moso »
https://forums.nicoclub.com/moso-u137641.html
Mon Nov 16, 2009 10:43 am
well you definately came to the right place for help. for starters lets try and figure out your cam problem. first off bc only sells 1 stage2 cam set for the ka24de. thay are interchangeable between the FWD and RWD models of the ka24de and when used in the 240sx you need to grind the rear part of the exhaust cam off so it will clear the head cover. once that is done it should be a direct drop in. all 240sx ka24de use the same timing chain components.. if you bought it off ebay this is why it was so cheap and dont buy timing stuff from ebay. if you not sure what year your motor is there should be a year stamped into the pass side of the block just under the head just in front of the transmission, as far as the head i dont know where that marking is. you could post up pics of the problem and the offending parts, see if someone here has been through this before.
