greggie195 wrote:From what I understand (from the FSM) it mounts in the trunk, behind the left panel (in the HB model). I think you need the tuner, the antenna and the bracket. Best I could find is that price as well. There is little to no info on this thing anywhere on the whole interwebs. Let me know if you do install it and I will do the same.
Yes I installed it last week and it went good.The cable from the head unit was already pluged into the head unit so no need to remove the head unit.The brackets is need to mount in a factory location in the behind the left panel (in the HB model).
