Sirius
gripdog7205
Car: 2004 Pathfinder
So I got my wife Sirius because she really liked mine, but I got the Direct Connect and it will not work because of the two antenna bose, so I bought an adapter but that did not solve the problem, not the right part, male female issue. Anyone know if an adapter is sold. Thanks
gripdog7205
Okay so no one on this forum has this problem, any advice?
fueler
Car: 2 Nissan's
2 BMW's
what type of connectors are you having a male female issue with? rca? stereo jack? or is it the damn antenna?
radio shack or a stereo shop might have the dual male or dual female connector that can get u running.
I have Sirius in my QX4 but its hooked up to an aftermarket deck via 1/4" stereo jack, never had it hooked up to the bose deck so i dont have any solid advice for ya
tresk21
Car: 2002 Nissan Pathfinder
Which method are you using to connect it to the back of the radio? I always use the Sirius FM Direct adapter. Using this method you will also have to have 2 nissan ant. adapters, one nissan to motorola and one reverse. What year QX/Pathy you working on?
cerveza_fiesta
Car: 1993 Pathfinder SE 4x4
in my 93 pathfinder I had the sirius running the direct connect thingy
http://www.crutchfield.com/S-I...MDA25
for over a year with no problems. I bought adapters at futureshop. One to go from the 2-prong nissan antenna lead to the coax antenna plug used on the sirius direct connect, then a reverse connector to go from the direct-connect to the head unit. As far as I know the 2-prong connecting the antenna to the sirius connector was useless since I lost the ability to listen to land-based radio, but who cares with the sirius. That's the reason you bought it in the first place right?
gripdog7205
2004 and I bought the one connector for the direct connect but but now I need the gender changer, anyone know where to find it.Thanks
