Sirius Sat Reciver OEM
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
millerg18
Car: 2007 Versa SL
My OEM Sirius stopped working this morning. Does anyone know where the reciver is mounted so I can check the connections and make sure nothing is loose.Thanks
millerg18
Car: 2007 Versa SL
UPDATE!!!!Took it into the dealer. The Sat Radio is not covered under the extended bumber to bumber they sold me.... They want to charge me over $400 to replace it. I was looking on EBay. Found one for $75. Does any one on here have one they are not using they would be willing to part with cheaper?
BTW- I still don't know where the receiver is located in the car if anyone can help.
Urq
Car: 82 Ur Quattro & 07 Black Versa SL CVT.
if you have a hatch back it is drivers side rear of trunk and I think I paid $109 for mine at the dealer few months back so yes $200 is the stealers mark up to replace something that takes 5 min to change outI would not buy from ebay as the unit has special plugs on it so a universal unit will not work
millerg18
Car: 2007 Versa SL
Thanks Urq... I have the factory sub back there so I guess I will have to pull it all apart to find it. The one I was looking at on ebay was a used factory unit.
audtatious
Was it a dealer add-on?
millerg18
Car: 2007 Versa SL
no it was factory installed. It is a 2007 when it came with Sirius in 2008 they switched to xm
Return to “Versa Technical Discussions”
