NY.AD.MAN »
https://forums.nicoclub.com/ny-ad-man-u71077.html
Sun Oct 28, 2007 5:03 pm
You can hook up the FM modulator to a standard radio, just as long as it has FM... and it does.
The FM Modulator, even when hard wired, uses only 3 different wires:
Antenna wire (you will need the adapter to do so), Power / ground wiring, and the connection to the actual unit. Just remember that the connection is NOT a direct connection and thus will not result in CD Quality sound.
But the point is yes, you can install an aftermarket FM modulator in a stock Versa S...
STILL: Get the aftermarket headunit setup, you will get better quality sound and the ability to control EVERYTHING through your stereo... go for Alpine if you do...
