Eswift wrote:maybe for our winters, as better snow tires often have this effect, but i doubt any all-season improvements on our car with that siping.
as winter tires with siping prove piss poor on dry pavement, i bet if you did the cuts yourslef, the effects would be similarly disappointing.
VimyJ wrote:I read a lot of articles about siping last night. Siping has been around since the 20's and was invented by a guy named Sipe. I read no comments about poor or decreaesed performance due to siping. In fact, many of the better articles were from Canada where they generally are more concerned about traction issues than we are here in the central part of N. America.
The primary reason snow tires perform badly on dry pavement is because of their agressive tread design. These tires only have about half the tread surface on the pavement compared to summer tires so their traction is correspondingly less.
The biggest benefit that I read was of increased tire life (attn. Q45tech). The siping allows the tires to run cooler slowing the vulcanization process. The trucking industry have run millions of miles on siped tires and have noted the increased tire life and increased traction. Other benefits were a quieter and softer ride.
The only negative reports had to do with poor siping jobs where inexperienced techs botched the job.
Tires can be siped as long as they have 50% of the tread remaining.
The squirming question was addressed in one of the articles. Apparently, siping decreases tire temperature because it isolates frictional heat building. Heat is not transmitted as well through the tire compound becuase of the sipes. If fact, certain road race organizations ban siping as an unfair advantage. The trucking industry has reported much greater tire life.EWT wrote:I have a very hard time believing that a local $8/hr tire shop employee cutting tread blocks is going to improve traction for all conditions on a tire that a tire manfacturer spending millions of dollars developing and making molds for. One of the main features of a tire designed for dry traction are big tread blocks that don't squirm around and wiggle while cornering since that creates heat, which leads to a loss of traction and chunking if it gets bad enough. Cutting slots in the tread blocks defeats that and turns big tread blocks into little ones that wiggle around and rub each other, creating heat. It may help for bad weather traction since you're creating more irregularities on the tread surface, and might somehow increase tire life driving in a straight line (not sure why this would happen though), but I am very dubious it helps dry weather traction. If it did, you'd see them all over the place at the racetrack, and I have yet to see a siping machine there.![]()
I'm still skeptical. Just because companies who provide the service and machinery to do it say it's the greatest thing since sliced bread doesn't mean it really is.VimyJ wrote:The squirming question was addressed in one of the articles. Apparently, siping decreases tire temperature because it isolates frictional heat building. Heat is not transmitted as well through the tire compound becuase of the sipes. If fact, certain road race organizations ban siping as an unfair advantage. The trucking industry has reported much greater tire life.
Eswift wrote:i know they do custom siping cuts on rally cars and it makes a tremendous difference for each individual run. The driver makes a judgement on how many cuts are to be made from the slicks, and often ends the day pissed at himself about his decision. seems to me that siping is definitley good for some slippery surfaces, i.e. snow for a normal car or rally HP on unpaved roads, but the amount of fine tuning necessary makes it impractible for the street. maybe for the winter, but again....just get snow tires with those mini channels built right in. all the good snow tires are molded with sipes now, look at tire rack.
VimyJ wrote:I would be hesitant to sipe my brand new tires but I might consider it when they're down to 50% tread.
I bought my tires at the Elgin location but they don't have the siping equipment. The nearest Discount Tire siping location to me is in Bloomingdale according to their web site.Eswift wrote:well VImy, im going to hold out on the siping until i can get some more info, but its a very interesting topic you have raised.
if you dont mind me asking, which discount tire location did you go to?
i too have been impressed with discount tire, but i never knew they did the siping.
Hmmm... Since siping is reported to reduce tire tempeature would this be counterproductive to balls to the wall road racing? F1 tires are stored in heated blankets so that they will have the maximum grip when changed on to the car and even then the tires are not up to racing temperature. If the sipes reduce temperature then this would reduce the "stickiness" of the tire compound on racing slicks. Of course, these F1 teams also have an almost infinite supply of tires for any track condition.Q45tech wrote:Slicks [100% SOFT rubber no groves no sipes no nothing have the greastest traction in dry and even moist roads.......Important to keep the rubber at the temperature which is optimum for molecular bonding
