CollegeBoy wrote:Ther is no point to do a single turbo. Also, basically, since you have an NA, you must do a full on Twin Turbo conversion if you want boost. People have boosted NA motors, but I find it silly b/c the gains are little since you can't run high boost and the price is not that much better.
Really? So how does the motor know if its a twin or single setup? The stocker will be fine to 6-7psi. Call Reed at Work Turbos and discuss it with him.
Twins are much more expensive.
Personally I dont like rear mounted setups. Turbos need heat. I was able to fit a 4788 in my 300 with a small block chevy, so room for a smaller turbo and the stock motor should not be an issue. Plan things out well and you will be ok. You will need injectors and a GOOD tune though.
Building a forged rotating assembly and running 20-30 psi will just destroy the driveline and twist the car up.
