SINGLE TURBO OR TWIN TURBO?
Josuke_Ling
Car: Nissan 240SX
ok i just got my 240sx for 1500 and im looking to turbo my car but i dont know what to go with and is it possible to do a twin turbo? i also need to know exactly what i need to turbo my car?
jab11185
Car: 1992 Nissan 240sx
have you seen that red blinking thing in the corner at all?
you can answer most of you own questions there....
as far as twin turbo....good luck with the plumbing nightmare
WDRacing
Try reading here first. Lots of good info.
http://www.penguinsstealmysanity.com/posting.html
Florida240sx
was going to twin turbo mine.But then decided I'll just drop a vg30dett in my project.So I can kill 2 birds with one stone.
SeVa-S13
Car: '05 GTO 6spd
Quintuple turbo is the only way to go. One turbo for each cylinder then a really huge one for the extra boost at your 12,000rpm redline.
1WheelWonder
Car: 1991 Nissan 240sx
Have fun finding room for the turbos and plumbing.
Florida240sx
That's why it's a project.If it is a simple task then it isn't a project.I might end up going with just a high snail instead.Getting a junkyard vg and building it.
wannawangan
Car: FOR SALE 1993 Nissan 240SX email me for more details
That is quite an interesting venture! To get an idea of what you may experience take a look at this thread about a member who was looking into that option for an SR turbo motor.
zerothread?id=57427
Conceptually, you can pull this off. However, you may find that tuning it may be a nightmare. Definitely NOT for the feint of heart!
Good luck though!
nismofly
Car: 89 Nissan 240SX Hatch
not worth it, ive done the research
Craving4Boost
Car: 91 240sx fastback
nismofly wrote:not worth it, ive done the research
this is true, it's not worth it. on a 4 cyl. engine it's no point. single turbo on a 4cyl. will have the advantage. only reason to do it is to use your money because some people got that much money heh..
Josuke_Ling
Car: Nissan 240SX
well i came by some shop thats in virginia thats 5 hrs away that i can go to that with charge me 2700 for a black top sr20det and 1100 for the work dos this sound good?
jab11185
sounds like crap......remember this is the KA-t forum....
Craving4Boost
you were talking about SR all this time?? just for the record even though you want to do a TT set up, the KA will work better than the SR
MarkEmark
Car: fully-built '95 240sx KA-T
SeVa-S13 wrote:Quintuple turbo is the only way to go. One turbo for each cylinder then a really huge one for the extra boost at your 12,000rpm redline.
LMAO
That's really your only option bud....anything less than 5 just ain't worth it
wannawangan
Depends what the 1100+ will cover. I'd say get a quote first. Since this is a KA-T forum, search and learn all you can as far as turbo'ing your KA. Should you need more info on the SR, then check out the SR forums. I posted the SR twin-turbo reference to give you an idea of what kind of work you should anticipate.
