Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Thu Jan 08, 2015 9:54 am
Minimally. Proper placement of a carrier bearing on a 2 piece shaft is to keep the two segments of the driveshaft as close to the same angle as possible - emulating what you'd have with a single piece. I'd stand by that the one piece is better in just about every way unless you have a ridiculously long vehicle. You will need a little larger tube diameter and/or thickness for a single piece if having one custom built.
